Old 02-15-2018, 11:47 AM   #6 (permalink)
mpg_numbers_guy
mpg_numbers_guy's Avatar
Toby - '13 Toyota Prius C
90 day: 61.95 mpg (US)
Daz - '15 Mazda 3 iTouring w/ Tech Package
90 day: 38.2 mpg (US)
Originally Posted by Daschicken View Post
I hope you lubed up those caliper slider pins good. If you feel like going back in there, you can make some brake pad return springs, i've got a video on them. Be careful to not make them too strong. I made mine very strong with the assumption that the hydraulic brake system would easily overpower them. Well, it does, but the initial pedal feel has changed. I have gotten used to it, but I would prefer it to bite more.
Don't remember if I put extra lube on them, but I do remember making sure they worked properly, since that seemed to be the issue with the caliper that came on the car.
I should hope you can achieve a 50 MPG tank, my best tank in the V6 accord was 44.6 MPG, and I just passed 50 MPG yesterday! I have yet to be called a ricer and my car looks like:
Is your car a manual or an automatic? How much have these mods improved your MPG?
You should be able to get some pretty helpful mods in even with maintaining a stock appearance. My car remained mostly stock looking for a while because of parents...
Lol! Resale value is also another thing to keep in mind, in case I ever end up reselling it when I buy a newer car later on.
Add an engine block heater to your list of potential mods, they are cheap, effective, and very nice to have in the cold.
Definitely something I've looked at, however budget does come into play with some mods.
When you are stopped(assuming engine on), do you shift into neutral while waiting? That is worth a 25-30% reduction in idle fuel consumption vs in drive, and gives a smoother idle.
I've considered that, but I just need to first make sure I stop trying to accelerate in neutral from forgetting to switch back into drive after coasting lol.
Welcome to the site and congrats on the great mileage with a stock automatic! Nicely done.
Thank you!
We have a member that wanted an HX and four doors. He did not make excuses.
Lol I'm sure it's possible! However a limited budget and zero mechanical experience hinder me somewhat from doing something like that.
2013 Toyota Prius C 2 (my car)
2015 Mazda 3 iTouring Hatchback w/ Tech Package (wife's car)
