Old 08-26-2008, 09:33 AM   #31 (permalink)
instarx
Volvo - '00 V70 XC AWD SE
90 day: 27.7 mpg (US)
Originally Posted by trikkonceptz View Post
And last but not least if your tank is larger than 15 gallon consider running with 1/2 a tank or less if possible for weight reduction there too ...that however messes with your mileage tracking, so pick your poison.
As a compromise don't fill up the tank when it is half full - run it to E. That allows you to spend half your time with a half-empty tank and still allows you to track MPG at fill-ups.
Also, tires make a huge difference. My truck lost 15% mileage when I switched from highway tires to M&S. Consider two sets of tires - highway tread for summer and use winter tires only in the winter.
