Old 02-21-2018, 02:16 PM   #15 (permalink)
gumby79
gumby79's Avatar
little jona - '91 Dodge D 250 first gen cummins LE
Team Streamliner
90 day: 23.4 mpg (US)
Little Jona airo modded - '91 Dodge RAM 3/4 TON D 250 2×4 AUTO
Pickups
The Salted Hound Jenny. - '87 Dodge Ram 50/D-50 5sp 4X4
90 day: 20.24 mpg (US)
Jona Allison aero - '91 Dodge Ram D-250 Le
90 day: 20.76 mpg (US)
You got a stiff one.
Many of the car manufacturers have gone to run flat technology tires. The reason for running the ultra stiff sidewall run-flat style Tire is to delete the weight of a spare tire. Unfortunately the downside is the tire doesn't deform until it has consumed itself due to the extra heat of the air not supporting the weight the sidewall is doing it insted. Every Tire I have stopped on the side of the highway to help someone stranded that has been one of these run-flat Technologies has disintegrated before the driver was aware that they had a low tire and then there's no spare tire I ruined rim and they're still stuck on the side of the highway. The only ones I've seen survive a picking up a nail have had the air monitoring systems that have become A DOT safety item, when the air pressure monitoring systems gained safety item status the aftermarket air pressure monitoring systems were pulled off the market unless they can pass the DOT testing procedures making them unavailable to vehicles like mine that don't have factory installed safety equipment.
On the bright side it only cost you 11 MPG instead of that plus a tire.
1st gen cummins 91.5 dodge d250 ,HX35W/12/6 QSV
ehxsost manafulld wrap, Aero Tonto
best tank: distance 649gps mi 24.04 mpg 27.011usg
Best mpg : 31.32mpg 100mi 3.193 USG 5/2/20
Former
'83 GMC S-15 Jimmy 2door 2wd O/D auto 3.73R&P
'79 Chevy K20 4X4 350ci 400hp msd custom th400 /np205. 7.5-new 14mpg modded befor modding was a thing
87' Hyundai Excel
83 ranger w/87 2.9 L FI2wd auto 18mpg on the floor
04 Mitsubishi Gallant 2.4L auto 26mpg
06 Subaru Forrester XT(WRX PACKAGE) MT AWD Turbocharged 18 plying dirty best of 26mpg@70mph
95Chevy Blazer 4x4 auto 14-18mpg
04 Chevy Blazer 4x4 auto 16-22mpg
