Old 02-22-2018, 08:28 AM   #10 (permalink)
All Darc
You are right. I must said drag coefficient instead of say just drag, when refering about Morelli 0,05 otherwise I would be reffering to another thing.
Drag coefficient it's the same for a vehicle or for a scale model of the same vehicle. For other side drag force it's different.
It's easier to a torpedo shell have reduced drag coefficient, as it have reduced drag force. The drag force fights less air with a reduced frontal area to push air.
For a solar car, the drag force it's important to calculate how much the motor will need to fight the atmosphere.
And there is also CDA, that is CD x Area (frontal). Os it can be calculated by removing the A in the equation od CD:
Some designs makes me a bit confused, like how define the frontal area, if by looking at it, in some cases, we see not a very clear division. I supose it's the area in a transversal cut, like cutting a salami, right? Is the point of cut would be until the wider area before it stat to get narrow? Is the point where the "salami slice" is larger ?
Originally Posted by darcane View Post
Keep in mind that the goal is to minimize drag with these cars, not just Cd. Drag is a function of Cd x A (frontal area). Flat solar cars may sacrifice a little Cd in order to greatly reduce frontal area.
