Old 02-27-2018, 10:43 AM   #11 (permalink)
rmay635703
home of the odd vehicles
rmay635703's Avatar
Silver - '10 Chevy Cobalt XFE
Originally Posted by 19bonestock88 View Post
Dual EFIE? I don’t follow...
Not sure what your asking
Modern cars have 2 o2 sensors a decent EFIE on each allows you to trick the car into thinking you are running rich and lean out.
A decent EFIE is variable and allows you to intercept your o2 sensor signal and set your AFR after you are up to cruising speed.
However a narrow band car looses resolution slightly above 15:1 AFR so you can’t normally get a car to run AFRs much above 15.2:1 with an EFIE
And no I’m not advertising, you can build an EFIE with less than $5 of parts there isn’t much to one.
