Old 03-02-2018, 11:19 AM   #2 (permalink)
Stubby79
Stubby79's Avatar
Firefly EV - '98 Pontiac Firefly EV
90 day: 107.65 mpg (US)
Little Boy Blue - '05 Toyota Echo
90 day: 33.35 mpg (US)
BlueZ - '19 Nissan 370Z Sport
90 day: 17.19 mpg (US)
Hmm.
Doesn't explain your self-heal, unless it finally knocked it completely loose and out of the clutch somehow...but I pulled the trans to replace the clutch on one of my cars and found one of the springs (I assume they are there to avoid chatter and/or absorb drive-line vibrations) on the clutch disk had a coil or so broken off. It was stuck in there. Different symptoms though...clutch would NOT disengage. Figure it was jammed in there, stopping things from working properly. Maybe you've just dislodged a spring that was broken and messing things up.
