Thread: I'm back!
Old 03-05-2018, 08:18 PM   #6 (permalink)
DSMHondaGuy
DSMHondaGuy's Avatar
Sipper - '98 Honda Civic HX
90 day: 40.14 mpg (US)
Well we have an engine code, G63B Pretty damn sure that's a Serius series Mitsubishi engine.
This was fun.
Not sure what this diaphragm is for, but it's not hooked up at all.
Didn't spot any obvious vac leaks. Didn't have time to work on adjusting the clutch cable or checking the parking break as thoroughly as i'd like to have. But I did note that the cables are moving and everything looks to be in working order for the parking break, yet, no parking break. So I assume it also need adjusting OR the pads are are so worn, or something funky is going on inside the rear drum brakes.
Did get the turning signal that wasn't working, working, without spending a dime. Just had to clean the contacts!
