Old 03-06-2018, 03:34 PM   #65 (permalink)
sidecar
Does this produce a datum line or the actual angle of attack?
Choose your tolerance for pain.
yes
but what you needed in the first place is a straighter roof with more bottom camber, then the line lifts at the tail to what appears to be negative lift (by AoA). Symmetric foils will not get you where you want to be
