Old 11-26-2007, 11:57 AM   #223 (permalink)
MetroMPG
90 day: 52.71 mpg (US)
90 day: 70.75 mpg (US)
90 day: 52.48 mpg (US)
01-08-2007, 01:44 Pm
Dax, the current limit of the golf cart controller is 275 A. And that value drops as it heats up from max duty cycle - 275 A is its 2 minute rating; 200 A = 5 min; 125 A = 1 hr.
(EDIT: and it was in 2nd - but I didn't have it "wide open" I would say 1/3 to 1/2 on the pot).
The forklift controller limit is in the neighbourhood of 400A, but it also has a bypass, which will feed full battery current to the motor under certain (logic) conditions.
So with the golf cart controller at 36V, we're limited to the equivalent of 275 A * 36 V / 746 W/HP = 13.3 HP. At 48 V we'd get 17.7 hp. (Not counting losses.)
EDIT: aw, what the heck - let's throw in some loss estimates too. PWM controllers are typically described as "above 90% efficient", and the motor may be 75% efficient. So now we're down to:
HP (golf cart controller @ 36v) = 13.3 * .9 * .75 = 9.0 HP
HP (golf cart controller @ 48v) = 17.7 * .9 * .75 = 12.0 HP
Still, 9 HP is theoretically enough to go 55 mph in this car on level ground (assuming you don't run out of power before you eventually accelerate to that speed). What else am I missing?
