Lesson learned the hard way: If you P&G, you need to trickle charge the battery at least once per week.
If you park outside in the sun, maybe you could put in a solar panel. Set it on the dash, mount it in a window, and plug into the 12V power outlet. You will need to either size the panel so as to not over or under charge, or put in an oversize panel and a charge controller.
