Originally Posted by JRMichler
Lesson learned the hard way: If you P&G, you need to trickle charge the battery at least once per week.
If you park outside in the sun, maybe you could put in a solar panel. Set it on the dash, mount it in a window, and plug into the 12V power outlet. You will need to either size the panel so as to not over or under charge, or put in an oversize panel and a charge controller.
I figure this would be a good workaround... the issue had a slow onset and it just slowly became less reliable about starting... I set aside a tank of fuel and now the car is starting fine but I’m now trying to sort out a misfire so no hypermiling is possible right now...
