Old 03-12-2018, 02:40 PM   #6 (permalink)
Daschicken
EcoModding flying lizard
Daschicken's Avatar
Cibbie - '88 Honda CBR 250R
Motorcycle
90 day: 48.49 mpg (US)
Rarity - '06 Honda Accord EX V6
90 day: 29.88 mpg (US)
Baby viff - '86 Honda VFR 400R
Motorcycle
90 day: 42.15 mpg (US)
Latios - '08 Suzuki SV650SF
Motorcycle
90 day: 64.56 mpg (US)
Mazda 3 - '14 Mazda 3 i Sport
90 day: 43.25 mpg (US)
Originally Posted by davelobi View Post
any reason I can't leave it full height? I mean, closer to the ground is better right? I know it'll scrape on a lot of approaches but who cares as long as it doesn't rip it loose or off.
Not necessarily. Air dams add frontal area, and they help up to a point, but too big will just add drag(Vs optimally sized. Too big may still reduce drag from stock.). You don't want to prevent ALL air from going under the car. Hard to tell from the angle of the picture, but it looks like you would have maybe an inch and a half of ground clearance? That is not a whole lot. I have 4 inches of ground clearance in my accord thanks to its front wheel deflectors, and it scrapes more than my brother's LOWERED miata.
Name:	IMG_4668 Downsized.jpg
Try out the air dam as is, get a baseline for coasting/mpg. I would strongly recommend keeping both the top and bottom parts of the air dam as they are shaped for good mounting and good airflow respectively. If you want to shorten it, try cutting it in the middle and sliding it up, then bolting it together.
Name:	cut air dam.png
-Kaze o tatakaimasen-
Best trip in V6: 52.0
Best tank in V6: 46.0
Best tank in Mazda: 49.9
Best tank in CBR: 61.3
Best tank in SV: 83.9
You can lead a fashion-conscious horse to unusual-looking water...
Last edited by Daschicken; 03-12-2018 at 05:36 PM.. Reason: All caps equals important
