Old 03-14-2018, 09:37 AM   #2 (permalink)
JRMichler
JRMichler's Avatar
Nameless - '06 GMC Canyon
90 day: 37.45 mpg (US)
22 Maverick - '22 Ford Maverick XL
90 day: 41.9 mpg (US)
Manual or automatic?
Put in a ScanGauge or Ultragauge and monitor the vacuum. If you are running 15" to 20" Hg during highway cruising, you would definitely benefit from a taller gear. If you are running 5" to 10" Hg vacuum during highway cruising, you are right at the best rear end ratio. Note that SG reports MAP, so 20" vacuum is about 5 PSI MAP.
As for passing, that's what the other gears in the transmission are for. Also driving skills like anticipation and getting a running start.
In the world of gas mileage, it is a good idea to know how much you are held up by not passing a slower driver. For example, if you normally drive 60 MPH and you are stuck behind somebody driving 55 MPH for 10 miles, your total delay is less than 55 seconds.
The Following 2 Users Say Thank You to JRMichler For This Useful Post:
Daox (03-15-2018), Daschicken (03-14-2018)
