Old 03-15-2018, 12:35 PM   #18 (permalink)
mpg_numbers_guy
mpg_numbers_guy's Avatar
Toby - '13 Toyota Prius C
90 day: 61.95 mpg (US)
Daz - '15 Mazda 3 iTouring w/ Tech Package
90 day: 38.2 mpg (US)
Originally Posted by 19bonestock88 View Post
The HCH1 also has a much smaller engine(1.3L) making much less power than your 1.7L...
True. Almost seems like the hybrid system does nothing for the fuel economy.
You may be able to use Hondata to reflash your ECU and add in lean burn at cruise and alter shift points of your trans, which *could* gain you between 10 and 20 percent... an HX swap, while more involved, could gain you a little more...
Sounds like a much easier solution...how complicated is it? Cost estimate?
People compare changing from automatic to manual to sex changes. Swapping engines, building a custom wiring harness, and having a custom tune installed very well may be easier.
Lol, does sound like a good comparison. If only there was an "easy" way to drastically increase MPG...but if there were then automakers would most likely already be implementing it.
2013 Toyota Prius C 2 (my car)
2015 Mazda 3 iTouring Hatchback w/ Tech Package (wife's car)
