Old 03-15-2018, 11:40 PM   #317 (permalink)
California98Civic
Cyborg ECU
California98Civic's Avatar
90 day: 66.42 mpg (US)
90 day: 3671.43 mpg (US)
repairs before mods
Originally Posted by 19bonestock88 View Post
4-5 coats of plasti-dip sound like a lot but it really does help with adhesion and it flaking off... I’ve had a few items dipped and never any real issues... when applied thick enough it holds on well enough...
I got the clear plastidip. Looking forward to this attempt. Did some white lettering paint on the tires.
My driverside door has been deteriorating for years: tint installer cracked indoor panel, I cracked indoor panel, the window crank operation was deteriorating, the arm rest cloth was faded unevenly, and then a couple months ago the outside door lever broke (again).
All those repairs finished today.
The best repair is the crank. To get it to roll up smoothly, I made a "washer" using old bike innertube sections and a little silicone lube spray into the crank shaft bearing housing. IT WORKS LIKE NEW NOW! I am shocked and happy.
EDIT: just to show off clean door card. There were two very visible crushed and cracked sections that showed though the soft-touch surface badly. I fiberglassed the back to get it smooth again. The arm rest was blotchy & faded, exterior door latch was broken, and the window crank was cranky. Fixed and cleaned.
