Old 03-17-2018, 10:58 PM   #11 (permalink)
hayden55
Sport Utility Prius - '10 Toyota Prius II
90 day: 52.98 mpg (US)
300k Sequoia 4WD - '01 Toyota Sequoia Limited 4wd
90 day: 20.19 mpg (US)
I'd probably get low rolling resistance car tires first before I got a new axle. The axle will help but its not going to be an absolute ton. Your ranger is specced out to weigh 3100 pounds. I would get you a set of either 195-65/15 Michelin Energy Saver a/s or some 195-65/15 Bridgestone Ep422. Your car weighs about the same as my prius (3050), and the load ratings work and I can still tow my boat and what not. My mpgs went from struggling to get 51 in spring weather to averaging 63 mpg (both were max effort). Key was I had 7 year old non low rolling resistance tires in the correct size but the actual tread width was also 6.2" vs 5.6" of my 185-65/15 ep422.
The key with the axle is finding something that is already assembled so its cheap to swap in. Ford axles are a dime a dozen and easy to find. I know im a mustang guy/ ford truck guy as well. I'd say go as low as you can on the gear ratios and you will more than likely gain a ton of mpgs from 55-65 but only a marginal amount at 70 mph. (3.08 3.15 3.33)
"I feel like the bad decisions come into play when you trade too much of your time for money paying for things you can't really afford."
