Thread: I'm back!
Old 03-18-2018, 10:30 AM   #16 (permalink)
DSMHondaGuy
DSMHondaGuy's Avatar
Sipper - '98 Honda Civic HX
90 day: 40.14 mpg (US)
So good news! I didn't need the front cable or rear brake shoes! So those can go back to the store for a refund. Was getting late by the time I started though and I had no one to help with the hydraulic brakes (pumping them) so I decided not to replace the wheel cylinders for now. And just get those parking brake cables swapped out.
Actually was going surprisingly easy considering how dirty the underside of the truck is. Until I get to the wheel back plate brake backing plate, whatever. And this little sob didn't want to cooperate so since it's no good anyway and I have a new one here. SCREW YOU BUDDY! grabbed the propane torch and heated the spring to anneal it. grabbed the wire cutters, snip snip snip hah! pulled the cable out so I had more room to work with that spring steel cage thing, has prongs that stick out so it can't be pulled out once installed, 3 of them, must take some special took to press all 3 in at once to remove it. Well I don't have that, but what I do have is that torch, so more fire will make it comply! Got it good and glowing hot, annealed nicely, then it was just push those prongs in and they stayed in, pulled it out and to the trash can it goes!
New one installed
Noticed this little bag of fun while working on the drivers side.. figured I never find them with eggs actually still in them, poked at it. Noticed a very unhappy looking mommy running around! I do NOT like spiders! I wanted to grab the torch for this too, but.. the gas tank was less than a foot away and the filler neck a few inches away... fire didn't seem like a prudent choice here... reminded me of the guy that burnt his house down because of a big ass spider (orb weaver I think)...Okay...well lets see how much they like kerosene in a can... i mean wasp & hornet spray. (stuff sure smells like kerosene...) Didn't seem to like it, good.. I'll remove that egg sack later.
Interestingly this side (drivers) used a C-clip instead of that cage thing.
Bye bye garbage.
Also decided to see what was in that vacuum distribution box...
See that hornet, I thought it was dead... until it moved! eek! damn it! last time one of those stung me, it got me on the hand, a week after one got me on the arm, that first one I had no reaction, the 2nd a week later my hand swelled up about twice the size of my other, looked like a balloon hand! Killed that little sob too!
[size=4]The list[/size=4]
DONE!
Headlights
Adjust Clutch Cable
Parking brake
Change oil/filter since who knows how old it is.
Battery hold down
Replace thermostat with correct temp spec unit
NEEDS TO BE DONE
Oil leak from distributor
Fuel hose routing
Verify there are no vacuum leaks
Replace garbage wiring
Replace windshield wipers
Get tag lights working
Re-jet carburetor possibly replace with Webber
Radiator fan
Inspect and replace timing belt and components if need be. As well as balance shaft belt.
Remove any unused connections, wires and hoses.
Replace passenger side door
Repair or replace bench seat.
Replace flywheel (missing teeth)
Replace seatbelts since I'm unsure if the recall has been performed.
Replace tail gate
Replace cracked windshield
Repair small spot in the bed/tray near the tail gate where it's damaged / hole
Replace rear passenger side tail light housing (got a hole in it)
Rebuild transmission
Replace shocks
Paint it myself
Trying to figure out what the next priority is. Flywheel? (pretty sure the one on the other engine has all it's teeth, replace the seal for the distributor? Radiator fan? Wipers? Windshield wipers are easy to cross off.. lets do windshield wipers next....then the fan.
P.S. She seems to be getting about 20.4mpg with the 2 barrel Holley marine 350cfm carburetor from a Ford 302 v8 inboard boat engine.... Not bad, but not good either, there's a spot in the throttle it doesn't like. Factory they were rated at 26mpg highway and I have been keeping it around 55mph not hausing it or anything since it's had some fairly shady repairs done that I'm fixing. Looks like it will probably get the Webber 32/36 DGEV carburetor...that's about $350 I was hoping to not have to spend. But first I'm going to try re-jetting it since there's no way the jet in it is even close to sized right for this little 2.0L engine. If driveablity and mpg get substantially better, I'll work with what's on it since the eventual goal is to put a 4G63 DOHC cylinder head and EFI on this G63B block.
