Old 03-18-2018, 11:37 AM   #88 (permalink)
Natalya
Engine-Off-Coast
Natalya's Avatar
Red 2000 Insight (2017 through 2019) - '00 Honda Insight 5MT
90 day: 64.72 mpg (US)
Red 2000 Lithium Insight (2020) - '00 Honda Insight LTO
90 day: 71.76 mpg (US)
https://www.superbrightleds.com/more...ink/4445/9995/
They have like different options for different cars. I didn't know this but apparently the 2010 Insight uses H11 bulbs for the headlights, but also a pair of 9005 bulbs as DRLs on low power and then when you turn the high beams on the 9005 bulbs come on again at high power in addition to the H11 low beams. So I probably also need to replace the 9005s, but like right now if I turn the LED H11 low beams on the incandescent 9005 DRLs turn off.
I had never seen anything like this before. My 2000 Insight has just one pair of headlight bulbs. I used to have a 2001 which had DRLs because it was Canadian, but the DRL mechanism in that car was just constant low current to the headlight bulbs.
The Following User Says Thank You to Natalya For This Useful Post:
California98Civic (03-18-2018)
