Old 03-19-2018, 02:35 PM   #14 (permalink)
hayden55
Sport Utility Prius - '10 Toyota Prius II
90 day: 52.98 mpg (US)
300k Sequoia 4WD - '01 Toyota Sequoia Limited 4wd
90 day: 20.19 mpg (US)
I'm sure it will hardly matter. When you get into LRR tires that actually matter i'm sure the 24" tires and the higher ratio axle will cancel out to about the exact same as stock. Go with whichever makes the most sense... (a 3.45 is only a 8% reduction, while a 195 LRR tires is a 10% increase in revs).
"I feel like the bad decisions come into play when you trade too much of your time for money paying for things you can't really afford."
