Thread: iDuino MPGuino
Old 08-27-2008, 09:55 AM   #56 (permalink)
cmags
cmags's Avatar
Scoob - '05 Impreza Outback Sport SE
90 day: 25.28 mpg (US)
Originally Posted by Axaday View Post
Well, I decided it wouldn't take THAT much time and I wouldn't sleep well wondering. So I did what dcb said. I just let the iron warm up and then touched every solder point. I found a few spots that didn't really seem to have that much solder on second inspection and I moved some around until I was better satisfied and then I plugged it into the computer again. For a second the red LED flickered a bit and then it started blinking one second on and off. If that program works, should I assume the other will can push on forward?
Sounds like you nailed it. If the LED started blinking right after bending it (temporarily) and then touching up the solder points, it sounds like you may have had just a bad LED connection, because the program did actually load properly. Either way, sounds like you're good to go forward and load up the MPGuino .pde. Did you build the other circuitry yet?
