Old 03-22-2018, 10:37 AM   #7 (permalink)
COcyclist
Aero Wannabe
COcyclist's Avatar
TDi - '04 VW Golf
90 day: 53.2 mpg (US)
Originally Posted by iikhod View Post
I would be more concerned about shutting off your turbo engine hot, with the turbo spinning wild after your pulse
X2. With my diesel Golf I only E-On coast (which I do a lot). With the key off you lose not only oil circulation to the turbo but also airbags, ABS, power steering and eventually brake boost, and it messes up my ScanGuage. In my experience you will not hurt your transmission from coasting briefly, even at higher speeds. Towing a car could conceivably be done over great distances and time, which may eventually do damage.
60 mpg hwy highest, 50+mpg lifetime
TDi=fast frugal fun
https://ecomodder.com/forum/showthre...tml#post621801
The power needed to push an object through a fluid increases as the cube of the velocity. Mechanical friction increases as the square, so increasing speed requires progressively more power.
