Old 03-25-2018, 04:20 PM   #160 (permalink)
wim2584
Question and thanks
Frst of all many thanks for all the rewrite work, the code is now much more understandeble , for me still very diffecult
Hello , I'm trying to make a MPGUINO for my motorcyle Yamaha Tmax 500,
I think your code is very close to my needs.
Unfortunately i'm not a expert in C++ , So to evaluate and maybe change is very diffecult for me.
Because I will use it on a motorcycle, I like to have a other (smaller) display, I'm thinking on a 0.94" OLED , but this library use a lot of memory.
My question wat is the best way to start ,and is it possible to connect this 0.94"Oled to the arduino uno or pro?
The Yamaha has a engine with:
two cilinder
two injectors
mechanical (in tank) fuel pressure regulator without interaction with ECU
a MAP sensor
a lamda sensor
many thanks in advance
The Following User Says Thank You to wim2584 For This Useful Post:
t vago (10-21-2022)
