Old 03-29-2018, 03:11 PM   #4 (permalink)
cRiPpLe_rOoStEr
Originally Posted by grswat View Post
Injector kill switch/pushbutton start
That may be good, even though my first and only attempt of EOC in a vehicle with automatic transmission was quite scary to say the least...
Alternator cut off switch/deep cycle battery
Even though some folks claim to do it fine with an alternator delete, I still consider it quite risky. But anyway, would an underdrive pulley be out of question?
Electric fan conversion
An electric fan is a quite cheap and easy mod which usually tend to have a great cost-effectiveness. Go for it.
Grille blocks/front air dam/belly pan
Independent rear suspension might make it easier to overcome driveshaft clearance issues with a full-lenght belly pan
2 inch lowering springs
Lowered SUVs, especially 4WD ones, look quite odd.
Switching from 265/70/17 tires to 255/75/17 tires or 265/70/18 wheels + tires
Possibly changing front/rear differentials from 3.73 to 3.55 or 3.31
Possibly the 255/75/17 would still be better than the 265/70/18 due to a (slightly) lower weight and the narrower tread. But anyway, since you're already considering to swap differentials for taller ones, getting a set of tyres with a larger diameter might become redundant at some point.
