Old 03-30-2018, 09:10 AM   #10 (permalink)
grswat
Workstar - '01 Ford Windstar SEL
90 day: 20.12 mpg (US)
2003 Expedition - '03 Ford Expedition
90 day: 14.96 mpg (US)
Well I am 2 for 2 on having free stuff. I measured the resistance of the fan and came up with 1.0 ohm between 2 of the wires. The controller I have is rated for 16 amps so that should work fine. The third wire is still a mystery as it had around 150 ohms to both other wires. Only thing I can figure is it was some kind of return signal to the ecm or a controller. Maybe returning fan speed and it would adjust voltage up or down to the fan. At any rate I'm just going to leave that wire unattached.
Took a quick glance at the engine bay and was a little surprised to find no fuse box under the hood. Guess I will have to run a ignition power wire from inside unless I find something else under hood. My rough measurement of the inside of the shroud is 21-22 inches so with a little trimming I think I can mate the electric fan to the existing shroud.
