Old 03-30-2018, 10:20 PM   #15 (permalink)
California98Civic
Cyborg ECU
California98Civic's Avatar
90 day: 66.42 mpg (US)
90 day: 3671.43 mpg (US)
Progress today
Here is a picture of the compressor fan motor you can see on the left of the above circuit diagram:
That connector test connected to rad fan motor connector ( follow the red wire from the upper right at the radiator to the lower left):
Here is the switch temporarily wired up through the firewall:
It works! But as I expected, the compressor fan connector only gets power when the air conditioner is turned on. That is not a very desirable set up. But it works, and it will be easily reversed when finished.
ID:	23783   Click image for larger version
ID:	23784   Click image for larger version
