Old 08-27-2008, 06:24 PM   #12 (permalink)
RH77
Hybrid Student Driver
RH77's Avatar
Teggy - '98 Integra LS
90 day: 33.02 mpg (US)
IMA - '010 Insight EX
90 day: 45.43 mpg (US)
Tessie - '06 TSX Base
90 day: 28.83 mpg (US)
Originally Posted by IndyIan View Post
In my experience automatic cars will not cut fuel to engine for a long time when you are off the gas. When you get your scanguage you will know for sure, just watch the instantaneous MPG gauge. I think this is to do with how an auto works.
As for EOC, since your tranny doesn't have a good reputation I wouldn't bother. Do coast in neutral idling though, idling uses way less gas than even using 3% throttle to keep the engine from braking.
Ian
I believe there's a glitch in the SG that doesn't show DFCO. My Acura shop manual states the same -- down to 1250 RPM. I think it's fairly instantaneous.
Some have installed a blinking LED to indicate if their injectors are firing -- or a multimeter may do the same for experimental purposes.
I commonly downshift to scrub speed, but rev-match to reduce wear.
RH77
Supporting those devastated by the Joplin Tornado
EF5 / 22-May-2011
_
_
