Old 04-05-2018, 04:39 AM   #12 (permalink)
cRiPpLe_rOoStEr
Originally Posted by Piwoslaw View Post
Greenpeace's Twingo SMILE[/URL]
That's interesting, but since it uses a custom engine it would be more difficult to do something similar. Well, unless you manage to modify a Honda CB 500 engine and make it fit
Originally Posted by Wikipedia
A smaller and more efficient engine: a supercharged flat-twin, four-stroke engine with four-valve technology in a boxer arrangement. A maximum torque of 75 N·m results from a swept volume of 358 cm3 at 2,900 rpm. The dynamic pressure supercharger makes sure the engine runs most efficiently at normal operating speeds. Most car engines are designed for optimum performance at maximum speed and load, which are in reality rarely used. At 55 bhp, the engine has the same performance as the original Twingo. Other performance parameters, such as maximum speed, elasticity and acceleration are the same or better.
