Old 04-06-2018, 10:24 PM   #18 (permalink)
Interstatement
I received the box from Mooneyes yesterday afternoon. Initial thoughts include:
-The covers do have a significant dome shape to them.
-The Ford Explorer rims I’m using pose a small problem: the outer face of the rim is a single piece that is welded to the rear section, as opposed to the historically predominant style of steel wheel that has a center section joined to an outer rim. Because of this, the flat portion of the outermost lip of the rim is much wider than many and the Moon-supplied Dzus Mount tabs need to be trimmed and re-worked a bit to fit and the weld bead will be very close to the Dzus receptacle. I’ll try to sort it out tomorrow before work if I can.
