Old 04-09-2018, 03:40 PM   #182 (permalink)
freebeard
Trianglês ??? We talked about use wood slices and foem sheets, to get the shape.
Perhaps I mis-remembered.
Taking it from the top. Assume a 3D model of the Morelli body. https://duckduckgo.com/?q=pepakura+d...alemoon&ia=web is software that allows cuts and flattening that result in patterns that can be cut from sheet materials, from paper to plate steel.
https://screenshots.en.sftcdn.net/en...designer-7.jpg
Obtaining the final form without wooden egg crates and cut and shaped blocks of foam strikes me as a potential time and money saver. A smooth convex shape like the Morelli body would have a very simple peel pattern.
Lightwave? If it works for you (and your system) go for it.
"We're deeply sorry." -- Pfizer
