Old 08-27-2008, 10:51 PM   #14 (permalink)
dcb
needs more cowbell
dcb's Avatar
pimp mobile - '81 gs 250 t
90 day: 96.29 mpg (US)
schnitzel - '01 Golf TDI
90 day: 53.56 mpg (US)
I recon, one of the next tasks is to figure out the PSI to RPM Map. I don't suppose you have a 20,000 PSI pressure gauge? No? Ok, for now lets assume that 200 BAR is at idle, and 1350 BAR is redline, and that it is just a linear function.
I think the next step might be to figure out the RPM from the injector pulse, then figure out a "pressure multiplier" (linear function based on RPM) to combine with the usPerGallon figure, and I think you will be in the ballpark.
