Old 04-09-2018, 11:51 PM   #7251 (permalink)
thingstodo
Ford Prefect - '18 Ford F150 XLT XTR
Tess - '22 Tesla Y LR
Originally Posted by shmuel View Post
hi, i would like to build this microcontroller and add some modefction, in order to run 3 engines. but i can't find most of the files needed, both in fabrication and in code. can you send me please ?
This controller is not the original 500A cougar controller. It is much larger, rated about 400V instead of 144V and 1600A not 500A.
I think this one would work better for your 3 motor application, since there are 3 IGBTs and 3 output cables that are normally all connected together .. but you could use one motor per IGBT.
I PMed you - if you respond with your email address I can send you the files that I have. The high power version has the .PCB files and .SCH files as well.
In THEORY there is no difference between Theory and Practice
In PRACTICE there IS!
The Following User Says Thank You to thingstodo For This Useful Post:
MPaulHolmes (04-11-2018)
