Old 04-10-2018, 05:39 PM   #24 (permalink)
RedDevil
90 day: 49.01 mpg (US)
Originally Posted by cr45 View Post
You appear to be confusing the term "inertia" with "kinetic energy".
A mass M moving at a velocity V has a kinetic energy of 0.5 * M * V * V.
This however is not inertia.
Inertia is a measure of a body's resistance to changes in velocity.
It can be found from Newton's second law F = M * A and thus M = F / A
As there is no gravity in space, astronauts determine their mass (inertia) in a special device that applies a force and the rate of acceleration is measured. The rearranged Newtons 2nd equation is then used to calculate their mass (inertia).
You are right. Inertia is mass (resistance to change speed), and rotational inertia is resistance to change rotational motion.
A bigger wheel has way bigger rotational inertia, but it covers a much larger distance than a smaller wheel rotating bat the same speed.
In the end what matters is how fast the thread moves - that's the same as the speed of the car, regardless of the size of the wheels.
