Old 04-12-2018, 01:29 PM   #7 (permalink)
Ecky
90 day: 42.54 mpg (US)
My opinion, the problem with flight is that it's far less efficient than ground travel, all else being equal. You expend energy staying aloft that tires do for free. I don't foresee flight as being common for every-day and short-range travel until energy becomes significantly cheaper.
And you bring up a good point about batteries. There ARE battery powered airplanes already, but they have relatively small payloads and short range.
https://newatlas.com/electric-aircra...stralia/52846/
A single charge can reportedly keep the plane in the air for up to one hour, with 30 minutes of extra power in reserve.
Although the article is very optimistic (and it's quite an achievement to have a working electric plane at all), it's important to note that this airplane cruises at less than 100mph, with A 100 mile range in perfect conditions. The interior volume is limited to two cramped passengers and zero cargo.
On the flip side, operation costs are lower and it's probably a lot more reliable/safe.
gone-ot (04-12-2018)
