Old 04-16-2018, 11:14 AM   #106 (permalink)
aardvarcus
aardvarcus's Avatar
Deep Blue - '94 GMC Suburban K2500 SLE
90 day: 23.75 mpg (US)
Griffin (T4R) - '99 Toyota 4Runner SR5
90 day: 25.43 mpg (US)
Was able to work on the project part of Friday, got the rest of everything hooked back up. Ended up redoing some things that didn’t turn out quite how I wanted, including replacing some fuel hose with bent aluminum fuel lines. Rolled it out of the garage, and started it up. All is good, other than a small oil drip off the oil filter adapter, looks like I need new O rings.
I pulled out the factory wiring harness and began going through it as I am planning on reusing about half the stock wiring. I will eliminate what is not needed, add other factory circuits from the 1991 parts vehicle (e.g. electro-mechanical cruise control), and will wire new anything else that is needed. I was originally going to 100% rewire the vehicle but have backed off on that idea. Everything that is 100% necessary to operate the vehicle is all new and already functioning, the other nice to haves like gauges and sensors I will reuse what wiring I can to save work, but it all will be fed from new fuses and relays as appropriate.
