7805 Automotive Replacement
Tell you what, Sourcing a 30 volt zener isn't terribly bad, it adds a component, but I cannot believe that there isn't a common 5 volt voltage regulator in existence designed for automotive use. Can somebody mouse around and see if the 7805 should be obsolete for automotive use and replaced with something better?[/QUOTE]
The LM2940.. was designed by National Semiconductor for auto applications with attendent power interruptions and spiking and is available with a 5v output. I'm not sure which temp. spec you're interested in, but in general the T0-220 variety runs just under $2 from DIGI-KEY.
I've watched the development of this project and am ipressed with the progress. Keep up the good work!
G. Taylor
Honda PC800 50mpg
