Old 04-20-2018, 09:37 AM   #14 (permalink)
cRiPpLe_rOoStEr
Probably the electric pusher trailer could be more versatile, and save you the time you would otherwise need for the in-the-field recharging. If you could make an aerodynamically-enhanced single-wheel trailer with a hub-motor, and compact enough to eventually store it on board while not in use, that would be interesting to say the least.
