Old 08-28-2008, 10:31 AM   #500 (permalink)
johnmyster
Brown Bus - '98 Sonoma X-Cab SLS
90 day: 31.37 mpg (US)
Originally Posted by bennelson View Post
Just to note,
The coffee can power brakes was just an experiment. I have not, nor am I planning on driving the car around with that setup.
I only rolled about 10 feet on my driveway playing around testing it. It does give more braking action then when there was no vacuum hooked up.
Could somebody give me more information on what it would take to swap out the brake booster for Manual Brakes, or have an adapter plate? I don't quite get it.
You've got two options.
1) Find a master cylinder with a smaller piston bore. That'll give you more line pressure with less pedal effort. I suggest racing supply sources to find something like this. Summit racing shows as small as 3/4".
Wilwood 260-1304 - Wilwood Aluminum Master Cylinders - summitracing.com
2) Move the pedal pivot point down, closer to the master cylinder. Thus, giving the pedal more leverage on the cylinder piston.
Meh Truck
