Old 08-28-2008, 11:25 AM   #508 (permalink)
MazdaMatt
2k2Prot5 - '02 Protege5
90 day: 33.82 mpg (US)
THIS THREAD
...explains how to use your (caliper) piston size and your pedal ratio to determine a suitable piston. I think that what I gathered is that smaller will give you a softer pedal and more travel and larger will give you a harder pedal with less travel. So you can likely combine this advice and the previous and find a "relatively small" honda MC (13/16ths?) and bolt it right on there.
