Old 04-29-2018, 09:56 AM   #70 (permalink)
Ecky
90 day: 40.51 mpg (US)
Originally Posted by elhigh View Post
And considering that, if you had a hybrid, you would only need it maybe once or twice per year and you only use about 7-10kW-h per grid charging session (depending on the efficiency of your charger, how much charge you give, etc), it wouldn't make a noticeable mark on your bill. My rates are about 12.5 cents/kilowatt-hour, so with a bad charger all the way from empty I add about $1.25 to my bill once or twice a year.
And my battery isn't that big and my charger isn't that bad, so my bill goes up less than that. It doesn't make a noticeable signal against the noise of everything else.
It's more like 4-700 watt hours to fully charge a Honda IMA battery.
