Old 05-09-2018, 01:58 PM   #41 (permalink)
oil pan 4
I was either going to put a few kw of solar on the finished guest house out building or get a leaf. I just have not had time dig up and replace the inappropriate wire the last guy installed. He put down 8/2 with ground to a 120-240 panel on a 60 amp tandem breaker at the main. There is no insulated 3rd wire to run neutral on and you can't run 60 amps on 8 gauge. I already replaced the 60 amp tandem with a 30 amp spare i had laying around so the house doesn't burn down.
So a leaf it is.
