I know that my 1985 crx hf cuts fuel while coasting in gear as long as the engine is still above a set RPM, my 1983 honda civic also does this, you can clearly see this in the wiring diagram for that car, I can dubble check but I'm pretty sure that my 1973-78 civic shop manaul also shows the fuel cut solinoides, 3-4 of them on the carburator allowing it to compleatly cut fuel, and a vacuum switch on the intake manifold that trips them when the throttle is closed and the engine is reve
__________________________________________________ ___________
There are no solved problems; there are only problems that are more or less solved.[U]All the best,Ethonof
