Old 05-10-2018, 11:09 AM   #2 (permalink)
Stubby79
Stubby79's Avatar
Firefly EV - '98 Pontiac Firefly EV
90 day: 107.65 mpg (US)
Little Boy Blue - '05 Toyota Echo
90 day: 33.35 mpg (US)
BlueZ - '19 Nissan 370Z Sport
90 day: 17.19 mpg (US)
It doesn't put out it's rated output all the time, only if there's enough of a load on it. It tries to maintain a steady voltage, up to when it hits it's limit.
Your options are:
Reduce your electrical load as much as you can.
Replace the alt with a smaller alternator.
Rewind your alternator to reduce output.
Change the alternator pulley to potentially reduce output.
Trick your alt in to lowering it's output voltage.
Add some "fancy" current-limiting circuitry.
Remove the alternator altogether.
Or any combination of the above.
