Old 05-11-2018, 10:39 AM   #374 (permalink)
Gasoline Fumes
Too many cars
Gasoline Fumes's Avatar
CRXFi - '88 Honda CRX XFi
Insight 256 - '00 Honda Insight
Gen-1 Insights
Insight 5342 (no IMA) - '00 Honda Insight
Gen-1 Insights
90 day: 66.3 mpg (US)
Originally Posted by California98Civic View Post
I set it to minimum lash spec because the research I did says doing so will enhance low rpm efficiency, torque, and emissions. Smog test coming this summer. With minimum lash, I will get more internal EGR, more exhaust scavenging, and more heat transfer to the CAT.
I'll admit I don't know the effects of lash on emissions. But increasing lash will reduce lift and duration, which is what you want for low-RPM. Most of my driving is at 1200-1500 RPM and I noticed a slight improvement in torque with excessive lash. And a lot more noise!
2000 Honda Insight
2000 Honda Insight
2000 Honda Insight
2006 Honda Insight (parts car)
1988 Honda CRXFi
1994 Geo Metro
