Old 05-11-2018, 11:46 AM   #375 (permalink)
California98Civic
Cyborg ECU
California98Civic's Avatar
90 day: 66.42 mpg (US)
90 day: 3671.43 mpg (US)
Originally Posted by Gasoline Fumes View Post
I'll admit I don't know the effects of lash on emissions. But increasing lash will reduce lift and duration, which is what you want for low-RPM. Most of my driving is at 1200-1500 RPM and I noticed a slight improvement in torque with excessive lash. And a lot more noise!
I am no expert, either. Here is the main text I have been examining... it is called "THE IMPACT OF VALVE EVENTS UPON ENGINE PERFORMANCE AND EMISSIONS" and the best way to get it is probably through a google search for the title. It is a PDF. I downloaded it without trouble so it seems safe. Take a look at how it explains the effects of timing valves. Lots of subtlety but in pretty ordinary language. Really useful. See if you read it the way I did.
Gasoline Fumes (05-11-2018)
