Old 05-17-2018, 10:33 AM   #10 (permalink)
seifrob
Permanent Lurker
seifrob's Avatar
Dáčenka - '10 Dacia / Renault Logan MCV 1.5 dCi (X90 k9k)
90 day: 42.53 mpg (US)
I took foam with reflective foil sold as flexible insulation and cut it to the shape of my car windows and put it on the sunny side. It is held there by sunshades from dollar store ( mesh on wire ). I also glued velcro strips to an old emergency blanket and make a kind of heat shield on the roof, attaching them to my roof rails ( hey, if you cannot remove them, use them well...). Member oldtamiaphile actually glued some foil to his van roof and measured a noticeable temperature drop.
