Thread: Just an idea...
Old 05-21-2018, 02:19 PM   #5 (permalink)
Vman455
Moderator
Vman455's Avatar
Pope Pious the Prius - '13 Toyota Prius Two
90 day: 51.62 mpg (US)
Tycho the Truck - '91 Toyota Pickup DLX 4WD
90 day: 22.22 mpg (US)
The one problem I see is, every air curtain I've looked at on a production car (and I've looked at most, if not all of them) sits in the middle-to-top area of the wheel housing, not the bottom. It might be easier to add these Ioniq air curtain ducts to your bumper cover while you have it off. At $6 per, it's a cheap, OEM-engineered solution that's pretty much guaranteed to work; all you have to figure out is how to get intake air to them.
What are the relative heights of the component parts?
Air curtains are for steerable wheels. Do you have rear-wheel steering? Else skirts.
The rear wheel 'curtain' as drawn is occluded by the side curtain anyway.
The 2018 Honda Clarity uses rear wheel air curtains.
As they demonstrated with the original Insight, the public won't buy skirted cars.
UIUC Aerospace Engineering
www.amateuraerodynamics.com
The Following User Says Thank You to Vman455 For This Useful Post:
freebeard (05-21-2018)
