Old 05-22-2018, 01:13 PM   #23 (permalink)
MetroMPG
90 day: 52.71 mpg (US)
90 day: 70.75 mpg (US)
90 day: 52.48 mpg (US)
active thermal management
Didn't see this engine efficiency feature in the original article:
Active thermal management can direct heat as well as cooling to different regions of the engine for faster warmup, more efficient combustion, and high-load cooling.
Source: https://www.greencarreports.com/news...on-2-cylinders
This, in combination with the electric water pump, can keep providing cabin heat in cold temperatures even when the engine auto-stop feature is active.
I know most conventional heaters will quickly run out of heat within a few seconds of stopping the engine, if the HVAC blower is still on.
