Old 06-01-2018, 02:53 AM   #14 (permalink)
gumby79
gumby79's Avatar
little jona - '91 Dodge D 250 first gen cummins LE
Team Streamliner
90 day: 23.4 mpg (US)
Little Jona airo modded - '91 Dodge RAM 3/4 TON D 250 2×4 AUTO
Pickups
The Salted Hound Jenny. - '87 Dodge Ram 50/D-50 5sp 4X4
90 day: 20.24 mpg (US)
Jona Allison aero - '91 Dodge Ram D-250 Le
90 day: 20.76 mpg (US)
Choices for rubber gears...
Most "H" or fasters speed rated tires eather have no load capacity or are 28" or smaller or10-30"wide drag rears.
To day I've found some options
32.18"D 235/55r22 (104w) 1984lbs 168mph $154 usd
31.41"D 275/25r26 (98w) 1653lbs 168mph $215 sud
30.04"D 255/50R20 (109Y) 2271lbs 186mph
B stock rpm +.20 od + 3.08 gear swap.
C as above + 3500 gov spring.
Now comes the question witch one will have the best coefficient of rolling resistance?
What effect will the different wheel sizes have?
Options 1 is 140.5 good for 130club +150club rated
option 2 is 137. 2mph@100% transfer of rpm. (The 518 non lockup torque converter has demonstrated a 5% loss of RPM)
Option 3 131.2mph this option will requires the 3500rp. Gov spring for the 130 club . And will be useable allthe way to 175 + to qualify for the long course.
1st gen cummins 91.5 dodge d250 ,HX35W/12/6 QSV
ehxsost manafulld wrap, Aero Tonto
best tank: distance 649gps mi 24.04 mpg 27.011usg
Best mpg : 31.32mpg 100mi 3.193 USG 5/2/20
Former
'83 GMC S-15 Jimmy 2door 2wd O/D auto 3.73R&P
'79 Chevy K20 4X4 350ci 400hp msd custom th400 /np205. 7.5-new 14mpg modded befor modding was a thing
87' Hyundai Excel
83 ranger w/87 2.9 L FI2wd auto 18mpg on the floor
04 Mitsubishi Gallant 2.4L auto 26mpg
06 Subaru Forrester XT(WRX PACKAGE) MT AWD Turbocharged 18 plying dirty best of 26mpg@70mph
95Chevy Blazer 4x4 auto 14-18mpg
04 Chevy Blazer 4x4 auto 16-22mpg
The Following User Says Thank You to gumby79 For This Useful Post:
aerohead (06-02-2018)
