Old 06-02-2018, 09:27 AM   #719 (permalink)
Tesla
The Truck - '02 Nissan GU Patrol ST
Parametric Teardrop Curves Equation update
I have re-done the equation with the specs from post 517 (3-Wheeler) just to explore those specs further, although it does come up with a 2.5:1 Aspect ratio, there are other issues which make it less than ideal.
I have made the x & y grid lines the same as the template so it's just a matter of lining up the height and length markers to compare, the overlay is below:
I think there's probably enough detail in the overlay to explain itself, particularly comparing the angles which start gentle but then accelerate to 27 degrees at the 80% mark, which breaks the 22 degree rule. Although the Aspect ratio is 2.5:1, the issue is that 1/3rd was in the fore body, which leaves the tail with a 1.67 tail ratio.
The Following User Says Thank You to Tesla For This Useful Post:
aerohead (06-02-2018)
