Old 08-29-2008, 02:48 PM   #6 (permalink)
trikkonceptz
Legend in my own mind
trikkonceptz's Avatar
Evil Pumpkin - '08 xD RS 1.0 #1633
90 day: 35.45 mpg (US)
Silent Silver Killer - '010 Insight EX
90 day: 51.5 mpg (US)
Hey Doax, you better set your goals higher .. 40mpg came real easy for me and I am automatic. Also let me know if you venture into higher tire pressure. I am having a bear of a time keeping my tires inflated @ 55psi. For some reason they will not hold the pressure and slowly leak back down to 47 psi. I have changed valve stems on the fronts but it looks like it is still doing it with no apparent leaks.
Let me know if you come up with something worth experimenting with, I'm willing to try it first if you are hesitant.
Thx NoCO2; "The biggest FE mod you can make is to adjust the nut behind the wheel"
I am a precisional instrument of speed and aeromatics
If your knees bent in the opposite direction......what would a chair look like???
